5 Pages<1234>»
Offline kilele
#21 Posted : 08 June 2013 21:11:34(UTC)
kilele
I like the template system of MSword to create cover pages (insert->cover page)
It's something like the 'Gallery' user interface but you see the effect instantly on the document when selecting an option. Then there would be a way to customize that template (axes, scales, legends, comboboxes, radiobuttons..), even a minimap to preview a number of predefined gui panels to be placed adjacent to the plot of that template (like the gui of the 3d plots from the above link).
Maybe it would be possible a way for the users to provide plot templates to the Online Gallery of SMath.
Edit:
I've seen the way MSword2010 manages plots. The problem with following completely that approach is that you hardly can trace it back to see how it works, it could be better a mix of this wizard/gallery along with a panel of simple gui controls (comboboxes,radiobuttons,checkboxes) to see "at first sight" the entire configuration of the plot in order to better understand how it is made and change it. Ideally there would be an expression updating itself so that one can see a kind of script as Martin requested.
Edited by user 09 June 2013 14:26:01(UTC)  | Reason: Not specified
Offline uni
#22 Posted : 20 October 2013 14:40:52(UTC)
uni
Updated: now properties can be saved.
Edited by user 20 October 2013 14:42:40(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
on 20/10/2013(UTC),  on 20/10/2013(UTC),  on 20/10/2013(UTC)
Offline mkraska
#23 Posted : 20 October 2013 23:37:17(UTC)
mkraska
Thanks for the update.
Is there any chance to set the defaults or to set the values via script?
Is it possible to have the font size of all elements independent of region size and comparable to the math region font size (just like in xy-plot)?
Offline Tinu
#24 Posted : 18 May 2014 20:32:05(UTC)
Tinu
Rank: Member
Switzerland
Was thanked: 14 time(s) in 12 post(s)
Hello
having used ZedGraph in the past because of the better formatting capabilities compared to the X-Y Plot pluging (besides Windows I am using also a Laptop with Ubuntu Linux and thus can't work with Maxima Sad I was wondering when to expect an update which can be used with the latest nightly build of SMath.
By the way, recently I stumbled over a plotting software called "Veusz" which is open source and can appearently be used inside other software.
Link: http://home.gna.org/veusz/.
Could this be a candidate for a new plugin?
Martin Inäbnit
Edited by user 18 May 2014 20:36:57(UTC)  | Reason: Not specified
Tinu attached the following image(s):
Offline uni
#25 Posted : 07 October 2015 13:41:36(UTC)
uni
Updated.
Russia ☭ forever
on 07/10/2015(UTC)
Offline ndtma
#26 Posted : 08 October 2015 07:01:33(UTC)
ndtma
Sri Lanka
Was thanked: 125 time(s) in 82 post(s)
Attached is a SMath file showing a ZedGraph, but the settings are not saved after reloading.
Can somebody help me?
File Attachment(s):
Test ZedGraph.sm (372kb) downloaded 133 time(s).
Offline uni
#27 Posted : 08 October 2015 08:34:08(UTC)
uni
It seems that the svn contains old sources. I need time to recover this part.
Russia ☭ forever
on 08/10/2015(UTC)
Offline ndtma
#28 Posted : 08 October 2015 09:01:15(UTC)
ndtma
Sri Lanka
Thanks Uni
Offline Tinu
#29 Posted : 08 October 2015 12:34:30(UTC)
Tinu
Rank: Member
Switzerland
Originally Posted by: uni Go to Quoted Post
Updated.
Thank you uni
#30 Posted : 09 October 2015 05:26:59(UTC)
"I do not know if XY plot plugin already has this feature of inserting text and graphical elements ?. [Radovan]"
Yes, Radovan: as long as the graphic object is a two columns plotting object.
Your next visit: "Samples" ... will attach two WS about best use of X_Y plot,
damned great for plotting parametric contours !
Just slde your text and/or calucalution results in the plot, like in Smath Quick PLot.
Cheers: Jean
Offline uni
#31 Posted : 10 October 2015 18:30:33(UTC)
uni
Updated. Recovered.
Russia ☭ forever
on 10/10/2015(UTC),  on 10/10/2015(UTC),  on 11/10/2015(UTC)
Offline ndtma
#32 Posted : 11 October 2015 05:53:16(UTC)
ndtma
Sri Lanka
Hi uni,
Thank you very much. It works now.
#33 Posted : 11 October 2015 07:12:12(UTC)
Ordinal X scale [Radovan]
_____________________________________
Is that what you call zgraph region ?
That reminds me the freeware "KyPlot" ~ year 2000,
was not bad but doing too little maths vs Mathcad 8 Pro.
Offline ndtma
#34 Posted : 11 October 2015 08:49:06(UTC)
ndtma
Sri Lanka
In ZedGraph how can I convert a line graph to a smooth curve, instead of having hard corners/angles?
Something like set IsSmooth to true?
Offline omorr
#35 Posted : 11 October 2015 11:59:38(UTC)
omorr
Serbia
I was just playing some time ago with Xaxis->Type. I am not quite sure if all of these are working well.
As far as I know, bar graphs can not be produced yet for example. Can not figure out how to put text on the X axis etc.
I think that uni had to use some stripped zedgraph version in SMath. Lots of options are still gray (not available)
Ah yes, I still have it on my computer. I was really amazed with KyPlot.
Unfortunately, its development stopped long time ago. Although still with bugs and rough edges, it still could be surprisingly useful.
Edited by user 11 October 2015 12:05:23(UTC)  | Reason: Not specified
Offline subseapark
#36 Posted : 02 November 2016 19:35:01(UTC)
subseapark
Is there a way to add custom text at a defined location to a plot created using the Zedgraph plugin?
I am trying to create a polar plot by suppressing the x-y axis and replacing it with a polar grid composed of a series of concentric circles and radial lines at 30 degree intervals. To give meaning to the grid I wish to add text to indicate the radial and angular values.
Example of a typical polar plot:
Polar Plot
Edited by moderator 02 November 2016 20:04:47(UTC)  | Reason: fixed image link
Offline uni
#37 Posted : 02 November 2016 22:19:42(UTC)
uni
ZedGraph (NPlot, DISLIN, matplotlib, gnuplot and other) not finished. I do not recommend use it now.
I'm searching universal way to store all parameters in auto mode. I can't continue developing without this feature. xyplot has the same problem. Now I haven't time for this.
If I find out how to save parameters then I will help you with other things.
Russia ☭ forever
#38 Posted : 05 November 2016 02:51:37(UTC)
Not sure if might be useful or it is a dead end, what about XmlSerializer? (serialization/deserialization example here)
Edited by user 05 November 2016 02:53:14(UTC)  | Reason: Not specified
#39 Posted : 06 November 2016 16:36:29(UTC)
I can't help wrt to your image Zedgraph, I don't have this plugin.
Visit "XY Radial Grid in Samples". Imitate polar plot, customise
the grid [colors, divisions, N circles/radii ...]
Offline alyles
#40 Posted : 10 November 2017 23:48:03(UTC)
alyles
I get an issue trying to install Zedgraph plugin with most recent beta. Not sure if it worked in previous verions.
Anyways it throws an exception. I attached the text.
I'm running SMath 0.98.6522
exception.txt (7kb) downloaded 38 time(s).
Guest (2)
5 Pages<1234>»
