Hello. TheWizEd wrote:When I create a new region Parent is Nothing. Did you try it with SMath Studio 0.93? Regards.
Joined: 04/07/2010(UTC) Posts: 178 Was thanked: 19 time(s) in 13 post(s)
Andrey,
Sorry its taken me so long to get back to you. Been busy with other things.
The Parent was not set immediately after the constructor but I trapped it in OnPaint and its set to a value.
Thanks. |
Ed |
Originally Posted by: TheWizEd Andrey, I've finished the controls and posted to the SVN. Have a look and let me know if there are any problems. I'm not a professional programmer so go easy on my coding. As you noted the controls had to reside in a dll with the same name so I couldn't figure how to sub class so I just used switches to manage the controls. One thing I noted is that the user could cut and paste a control with no way for my program to capture that and rename the control to a unique name, which is needed by the program. Maybe next release. Hi, this work will be implemented in a future relase of smath? regards, w3b5urf3r Edited by user 09 January 2013 20:15:19(UTC)
TheWizEd,
I am looking at creating the same controls you indicated in this thread.
I am under the impression that you use Visual Basic to generate the controls? Yes? If so, could you walk me through the process you use to generate a button?
I downloaded an analyzed the code for a simple checkbox region and, despite not touching C++ in a while, I was able to modify the given code in C# to some degree (change color, change 'shape' of control). However, I would prefer not to reverse engineer if I don't need to.
Can you (or someone) create a 'control' development tutorial for Visual Studio?
