2 Pages12>
Offline Ber7
#1 Posted : 26 January 2014 10:10:20(UTC)
Ber7
Israel
Was thanked: 520 time(s) in 288 post(s)
Application of the method A.B. Draghilev to the calculation of the kinematics and animation
spatial mechanisms developed prof.A.B.Ivanov, that
develops method A.B. Draghilev to solve practical problems.
Their development, with detailed explanations,
he published on the site
http://forum.exponenta.ru/viewtopic.php?t=12842
The following examples are taken from this site and transferred from Maple in the programming environment SMath Studio.
A huge thanks to Alexei Ivanov, who gave me great help in the study the method of A.B .Draghilev.
1.Explanatory example
http://ru.smath.info/for...matsii-miekhanizmov.aspx
Edited by user 26 January 2014 10:13:25(UTC)  | Reason: Not specified
thanks 2 users thanked Ber7 for this useful post.
on 31/01/2014(UTC),  on 07/05/2016(UTC)
Offline Ber7
#2 Posted : 26 January 2014 10:18:11(UTC)
Ber7
Israel
One end of the rod moves in the spatial
curve, the other along a circular arc.
File Attachment(s):
Primer3.smz (9kb) downloaded 141 time(s).
thanks 3 users thanked Ber7 for this useful post.
on 26/01/2014(UTC),  on 31/01/2014(UTC),  on 07/05/2016(UTC)
Offline Ber7
#3 Posted : 26 January 2014 10:21:47(UTC)
Ber7
Israel
Three-link spatial mechanism
Edited by user 14 September 2015 13:28:52(UTC)  | Reason: Not specified
File Attachment(s):
Pr4.smz (10kb) downloaded 92 time(s).
PrUgol.smz (11kb) downloaded 82 time(s).
Offline Ber7
#4 Posted : 26 January 2014 10:25:04(UTC)
Ber7
Israel
Spatial four-bar linkage1
Spatial four-bar linkage 2
Artobolevskij.smz (11kb) downloaded 71 time(s). Primer5.smz (47kb) downloaded 139 time(s).
Edited by user 09 November 2015 11:46:02(UTC)  | Reason: Not specified
Offline Ber7
#5 Posted : 26 January 2014 10:30:32(UTC)
Ber7
Israel
Cardan Mechanism.The axes of rotation intersect at an angle of 45 degrees
Edited by user 21 May 2014 16:59:17(UTC)  | Reason: Not specified
File Attachment(s):
Kardan13542.sm (73kb) downloaded 140 time(s).
KardanHadash1.sm (90kb) downloaded 97 time(s).
Offline Ber7
#6 Posted : 11 April 2014 09:45:17(UTC)
Ber7
Israel
Animation curve, which is defined implicitly
Each loop equation "cam"-an implicit function F (x, y) = 0
  Examples taken from the site
Edited by user 11 April 2014 22:49:12(UTC)  | Reason: Not specified
File Attachment(s):
KulakMalben2.smz (6kb) downloaded 107 time(s).
Kulak2.smz (6kb) downloaded 86 time(s).
Kardeoida.smz (8kb) downloaded 96 time(s).
on 19/04/2014(UTC),  on 07/05/2016(UTC)
Offline Ber7
#7 Posted : 03 May 2014 00:06:20(UTC)
Ber7
Israel
The line of intersection of the torus and sphere(Villarceau circles)
This example is taken from an article by Дубанов А.А. :Численно-аналитическое
построение линий пересечения поверхностей методом Драгилева,2007(rus)
http://www.blagovest2002...urfInt/paper1/Paper1.htm
File Attachment(s):
Villarceau.smz (10kb) downloaded 112 time(s).
on 05/05/2014(UTC),  on 07/05/2016(UTC)
Offline Ber7
#8 Posted : 12 May 2014 21:02:38(UTC)
Ber7
Israel
The same mechanism with spherical linkages
These linkages have the property that
every link in the system rotates about the same fixed point. Thus, trajectories of
points in each link lie on concentric spheres with this point as the center. Only the
revolute joint is compatible with this rotational movement and its axis must pass
through the fixed point.
Edited by user 07 November 2015 19:15:45(UTC)  | Reason: Not specified
on 12/05/2014(UTC),  on 16/05/2014(UTC),  on 07/05/2016(UTC)
#9 Posted : 16 May 2014 14:03:17(UTC)
Was thanked: 1405 time(s) in 914 post(s)
I can't see the last image (neither in the russian side of the forum) Confusion
Offline Ber7
#10 Posted : 16 May 2014 18:01:47(UTC)
Ber7
Israel
Link to the file and image:
http://smath.info/wiki/GetFile.aspx?File=Guk.gif
File Attachment(s):
KardanHadash.smz (12kb) downloaded 68 time(s).
Offline Ber7
#11 Posted : 02 June 2014 18:36:46(UTC)
Ber7
Israel
Ring instead of cross-piece
File Attachment(s):
KardanHadash3.smz (14kb) downloaded 82 time(s).
on 19/07/2015(UTC),  on 07/05/2016(UTC)
Offline Ber7
#12 Posted : 18 July 2015 16:45:48(UTC)
Ber7
Israel
3-PRS Parallel Manipulator
Edited by user 31 August 2015 00:03:26(UTC)  | Reason: Not specified
File Attachment(s):
Tripod1s.smz (15kb) downloaded 71 time(s).
Tripod2s.smz (16kb) downloaded 69 time(s).
Tripod2s.pdf (254kb) downloaded 108 time(s).
Offline Ber7
#13 Posted : 30 August 2015 23:51:05(UTC)
Ber7
Israel
The Delta Parallel Robot
Kinematic scheme and dimensions are taken from the book
R.L. Williams II, “The Delta Parallel Robot: Kinematics Solutions”, Internet Publication,
April 2015.
Delta.smz (506kb) downloaded 169 time(s). Delta.pdf (543kb) downloaded 244 time(s).
Edited by user 15 November 2015 23:50:53(UTC)  | Reason: Not specified
File Attachment(s):
on 01/09/2015(UTC),  on 02/09/2015(UTC)
Offline Ber7
#14 Posted : 14 September 2015 11:37:56(UTC)
Ber7
Israel
RSCRmod.sm (107kb) downloaded 44 time(s).The RSCR spatial mechanism.
The calculation is borrowed from the publication of Alexey Ivanov
http://www.mapleprimes.c...0-RSCR-Spatial-Mechanism
A case where the axis of rotation are perpendicular
Edited by user 11 February 2016 13:01:02(UTC)  | Reason: Not specified
File Attachment(s):
RSCRmechanism.smz (16kb) downloaded 69 time(s).
on 14/09/2015(UTC),  on 07/05/2016(UTC)
Offline Ber7
#15 Posted : 23 October 2015 23:19:26(UTC)
Ber7
Israel
Again The Delta Parallel Robot.Winding onto a cylindrical mandrel
File Attachment(s):
Delta2.smz (602kb) downloaded 113 time(s).
on 24/10/2015(UTC),  on 07/05/2016(UTC)
Offline Ber7
#16 Posted : 27 October 2015 18:26:45(UTC)
Ber7
Israel
Delta3.smz (601kb) downloaded 78 time(s).Version for conical spiral
Edited by user 28 October 2015 19:05:16(UTC)  | Reason: Not specified
on 21/11/2015(UTC),  on 07/05/2016(UTC)
Offline Ber7
#17 Posted : 21 November 2015 14:37:36(UTC)
Ber7
Israel
Delta0C.smz (322kb) downloaded 113 time(s).In the above animation three links that support the lower platform is a simplified and
presented in the form of red rods. Actually used parallelograms (pantographs), where top and
bottom mounted universal (cardan) joints. Each universal joint implemented using Three
revolute joints . The axis of the middle joints lies in the plane of the parallelogram, and
axis external joints perpendicular to this plane. Animation of this design is shown below.
Edited by user 21 November 2015 14:39:55(UTC)  | Reason: Not specified
Offline Ber7
#18 Posted : 07 May 2016 13:55:01(UTC)
Ber7
Israel
Graf.smz (145kb) downloaded 53 time(s).Spatial (spherical) Cam
The idea is taken from here
http://www.mapleprimes.c...-MapleSim-#comment225311
Edited by user 17 September 2016 20:42:00(UTC)  | Reason: Not specified
on 07/05/2016(UTC),  on 09/05/2016(UTC)
Offline Ber7
#19 Posted : 30 July 2016 13:23:41(UTC)
Ber7
Israel
A mechanisms similar to slider crank mechanism
These mechanisms are shown Alexey B. Ivanov on the website
https://vk.com/away.php?...F204684-Lever-Mechanisms
1.sm (37kb) downloaded 62 time(s). 2.sm (48kb) downloaded 54 time(s).
thanks 1 user thanked Ber7 for this useful post.
on 02/08/2016(UTC)
#20 Posted : 02 August 2016 21:22:02(UTC)
Thanks Ber7 for your repost/new animations. Some don't work in Smath 5346,
so what. Animation is a very nice feature from Smath.
Rotate XY.sm (475kb) downloaded 50 time(s).
2 Pages12>
