4 Pages<1234>
#41 Posted : 29 September 2014 20:40:32(UTC)
Was thanked: 1203 time(s) in 794 post(s)
Thank you both, I've made a patch that seems to work. (SS-1224 opened)
PLUGIN UPDATED
Important: please report here if anyone notice a "PrePainter" error message on this region.
Best regards,
Davide
Edited by user 30 September 2014 13:49:36(UTC)  | Reason: Not specified
Offline brotjob
#42 Posted : 30 March 2015 11:28:26(UTC)
brotjob
Switzerland
I would like to use cases because if you nest i.e. 10 if loops the code looks ugly. But cases seems not to work with conditionally formatted labels. Is there a nice looking workaround?
brotjob attached the following image(s):
#43 Posted : 30 March 2015 16:42:47(UTC)
I'm from smartphone so I can't guarantee, but an eval(cases(...)) should works
Offline brotjob
#44 Posted : 30 March 2015 17:13:59(UTC)
brotjob
Switzerland
works like a charm!
Offline bAiLeY
#45 Posted : 02 June 2015 20:38:23(UTC)
bAiLeY
I am trying to create a label that displays " full psi " for a ratio greater than 2, but if the value drops below 2, it needs to display the actual value needed to maintain the ratio. I have it working except that it is stuck in symbolic format and displays an obscenely large fraction instead of the decimal value I need.
I have checked all of my formats and everything is in decimal and optimized to numeric. I have tried converting to a string with num2str and rounding the fraction to a decimal value.
Please help!
bAiLeY attached the following image(s):
Offline bAiLeY
#46 Posted : 02 June 2015 21:43:01(UTC)
bAiLeY
Thank you! This worked exactly like I needed to. And I agree, quite buggy.
#47 Posted : 03 June 2015 01:14:01(UTC)
I'll check it. BTW it is possible to use an eval() on the first argument.
on 03/06/2015(UTC)
Offline Engr
#48 Posted : 17 May 2018 22:53:41(UTC)
Engr
Rank: Member
Was thanked: 6 time(s) in 4 post(s)
Would it be possible to add a button style to the Conditionally Formatted Label that had no black line border. The button style could be called "NoBorder" or something similar. I use the conditionally formatted label for displaying design checks as shown below
and I think it would be nice to not have the border around the equality sign (>).
Another possible use would be for repeating text in a header on multiple pages and not have borders around the text or quotes around the text if it is a string variable as shown below.
And if the background color could be set to transparent that would be crowning achievement.
Thanks for your consideration.
#49 Posted : 18 May 2018 00:23:50(UTC)
Was thanked: 854 time(s) in 684 post(s)
For the remaining of the question, work sheet would help.
Image Formated LABEL [Oxyhemoglobin].sm (18kb) downloaded 36 time(s).
on 18/05/2018(UTC)
Offline Denis.N
#50 Posted : 18 May 2018 08:56:53(UTC)
Denis.N
Rank: Member
Engr, try using Table Region.
Use setings like on the screenshots.
2018-05-18_08-44-47.png Table region.sm (6kb) downloaded 37 time(s).
SMathStudio_Desktop_2018-05-18_08-38-02.png SMathStudio_Desktop_2018-05-18_08-41-10.png
thanks 1 user thanked Denis.N for this useful post.
on 18/05/2018(UTC)
#51 Posted : 18 May 2018 10:58:14(UTC)
Would it be possible to add a button style to the Conditionally Formatted Label that had no black line border [...] And if the background color could be set to transparent
I think they are both feasible options Good
If the content is not related with calculation an option is even to use metadata content in fields objects of writer regions
Edited by user 18 May 2018 23:43:24(UTC)  | Reason: Not specified
#52 Posted : 07 June 2018 13:40:38(UTC)
PLUGIN UPDATED Beta
  • context menu: added border on/off option;
  • "transparent" is now a valid color name;
  • alpha channel of colors now blends with underlying objects;
  • text wrap issue on printing mitigated;
Edited by user 07 June 2018 13:54:41(UTC)  | Reason: Not specified
thanks 6 users thanked Davide Carpi for this useful post.
on 07/06/2018(UTC),  on 07/06/2018(UTC),  on 07/06/2018(UTC),  on 07/06/2018(UTC),  on 08/06/2018(UTC),  on 08/06/2018(UTC)
Offline Engr
#53 Posted : 08 June 2018 18:05:21(UTC)
Engr
Rank: Member
Davide - thank you for revising the plugin per my suggestions. The revised plugin works for me very well. Per your postscript note I made a donation to Smath Studio for your efforts.
Offline Scudelari
#54 Posted : 06 May 2019 10:21:34(UTC)
Scudelari
Luxembourg
is this plugin working with version 0.99 of SMath? I can't find it to download from the application's plugin manager.
Thanks,
Offline PompelmoTell
#55 Posted : 06 May 2019 11:32:50(UTC)
PompelmoTell
Was thanked: 95 time(s) in 80 post(s)
in my installation (win7 PRO) it works correctly
#56 Posted : 06 May 2019 15:39:31(UTC)
From SS 6179
#57 Posted : 06 May 2019 17:34:54(UTC)
Here is the creator, adapted/augmented from Martin.
2D Util Bar Fourier_Martin.sm (76kb) downloaded 42 time(s).
#58 Posted : 07 May 2019 16:37:34(UTC)
... finally: does it work one way or another ?
on 07/05/2019(UTC)
Offline veb
#59 Posted : 26 November 2019 09:41:57(UTC)
veb
Hello!
Sometimes you want the calculation to show by which formula the calculations were performed. Use for this combo boxlist is not beautiful. Formatted label would be more accurate. But Formatted Label does not display a formalized formula. Is it possible to add such a possibility to the formatted label? And in addition, the ability to remove the frame around the edges of the formatted label?
Thanks in advance!
#60 Posted : 26 November 2019 10:30:29(UTC)
I think is not a problem 😉
4 Pages<1234>
