5 Pages<12345>
Offline uni
#41 Posted : 22 February 2014 13:30:19(UTC)
uni
Russia ☭ forever
Viacheslav N. Mezentsev
on 22/02/2014(UTC),  on 27/02/2014(UTC)
Offline tomtit
#42 Posted : 27 February 2014 20:54:13(UTC)
tomtit
Hi Uni,
For some reason, I always have the same error, using mwfprintf() function.
It looks the same on both 32-bit and 64-bit Windows.
Could you explain what is wrong here ?
Edited by user 28 February 2014 00:17:45(UTC)  | Reason: Not specified
tomtit attached the following image(s):
Offline uni
#43 Posted : 28 February 2014 00:45:27(UTC)
uni
Hi Igor.
There is a log.txt in the plugin directory: \extensions\plugins\4c2faab1-4d93-4904-8d88-a4e21512d179\1.0.4987.26944\
If you look at the contents, you will see errors when working with functions.
In this case, we see a problem in converting the operation result. Probably something has changed in the SMath Studio and my examples stopped working correctly.
mwfprint() works fine, but you need to set the current folder or absolute path. The error occurs after running the function while trying to return the result of work in bytes.
I will try to fix the error, if I can. Now I don't have the latest source.
Russia ☭ forever
Offline uni
#44 Posted : 18 March 2014 03:01:41(UTC)
uni
Russia ☭ forever
Offline uni
#45 Posted : 11 April 2014 21:55:34(UTC)
uni
Originally Posted by: tomtit Go to Quoted Post
Hi Uni,
Updated. Try now (with SMathStudio_Desktop_0.97.5189_32bit.exe for 64-bit).
Edited by user 11 April 2014 22:01:14(UTC)  | Reason: Not specified
Russia ☭ forever
Offline RFreund
#46 Posted : 12 April 2014 01:52:17(UTC)
RFreund
Was thanked: 19 time(s) in 17 post(s)
I'm curios to know -
There is a plugin for using Maxima and a plugin to use Matlab/C++, is there advantage to starting using one over another? I mean is one more/less powerful. Is one better with units or symbolic?
Thanks!
Offline uni
#47 Posted : 12 April 2014 09:11:10(UTC)
uni
Updated. mwfscanf() now working too. Relative path also works. Strings as parameters not supported for now.
Thanks!
You can get these plugins from the Extensions Manager (I don't know how it called in english). They are very different. Matlab C++ Math Library - just a numeric library, not symbolic. Full description you can get from the MATLAB C++ Math Library. User's Guide. Version 2.1.pdf. Also, no need to install Matlab.
Edited by user 12 April 2014 10:42:39(UTC)  | Reason: Not specified
Russia ☭ forever
Offline mkraska
#48 Posted : 12 April 2014 12:34:42(UTC)
mkraska
Advantages of the matlab lib plugin:
  • more functions
  • more uniform and consistent function interface
  • better documentation (you can use original matlab docs in the web )
  • easy installation (just download the plugin)
  • certainly more performant numerics (did not benchmark this)
Advantages of the Maxima plugin
  • symbolic math
  • units handling
  • safe legal status
  • graphics functions (matlab has better ones, but they are not exposed to SMath in the plugin)
on 12/04/2014(UTC)
Offline RFreund
#49 Posted : 14 April 2014 18:08:55(UTC)
RFreund
Thank you Martin and Uni
Offline Dr. Parnassus
#50 Posted : 18 July 2014 12:32:40(UTC)
Dr. Parnassus
Switzerland
Hi Uni,
I would use the svd-function from the matlab c++ Math Library.
But the function is not available.
Thanks and best regards
Dr. Parnassus attached the following image(s):
Offline uni
#51 Posted : 18 July 2014 17:34:06(UTC)
uni
The fact is that not all functions realized. Only blue ones with the mw prefix exist.
Russia ☭ forever
Offline uni
#52 Posted : 27 July 2014 14:17:40(UTC)
uni
Updated. svd() added, but I'm not shure about how it works (correctly or not).
uni attached the following image(s):
Russia ☭ forever
Offline omorr
#53 Posted : 27 July 2014 15:38:32(UTC)
omorr
Serbia
I think something is wrong here. U matrix has extra column and S matrix should bi diagonal.
Offline uni
#54 Posted : 27 July 2014 15:55:26(UTC)
uni
Matlab svd example. S - transposed (I don't know why).
Russia ☭ forever
Offline uni
#55 Posted : 27 July 2014 16:15:38(UTC)
uni
Updated. svd() fixed.
Edited by user 02 August 2014 12:11:25(UTC)  | Reason: Not specified
Russia ☭ forever
on 27/07/2014(UTC)
Offline omorr
#56 Posted : 27 July 2014 16:28:48(UTC)
omorr
Serbia
I see. Thank you uni. I thought on [U,S,V] = svd(X,0) only.
#57 Posted : 30 July 2014 09:08:50(UTC)
Dr. Parnassus
Switzerland
Thank`s uni! Now I can continue my work in smath.
I will close matlab at once :-) - best regards.
Offline omorr
#58 Posted : 30 July 2014 13:51:59(UTC)
omorr
Serbia
By the way, there is Dot Numerics plugin - by uni
Offline idushy
#59 Posted : 26 September 2014 10:01:58(UTC)
idushy
Что обозначает в заглавном посте зеленый и синий цвет функций. Зеленые smath не "видит". Как заставить его их увидеть? Спасибо.
Edited by user 26 September 2014 10:17:43(UTC)  | Reason: Not specified
Offline uni
#60 Posted : 26 September 2014 15:23:01(UTC)
uni
Синие с префиксом mw реализованы, остальные ещё нет (по запросу), поэтому они не видны.
Russia ☭ forever
Guest (2)
5 Pages<12345>
