Good, nice worksheet From the smartphone I've missed your first screenshot. If you open and save the file from SMath portable your worksheet should works also with the latest plugin, I'm sorry for the inconvenience Edited by user 05 February 2014 13:51:58(UTC)
UPDATED
(SMath Studio 0.97.5189)
- code updated to fit the new APIs features; |
Joined: 18/09/2014(UTC) Posts: 71 Was thanked: 7 time(s) in 7 post(s)
I just lost one day of work because of this plugin. Because it crashes sometimes when entering formatted labels I saved my changes regularly. But now I have a corrupt file, a crash occurs immediately after opening I'm using v0.97 build 5346
Originally Posted by: brotjob I just lost one day of work because of this plugin. Because it crashes sometimes when entering formatted labels I saved my changes regularly. But now I have a corrupt file, a crash occurs immediately after opening I'm using v0.97 build 5346 I'm sorry for that... can I help you to recover the file? If you can't share it here, send me an e-mail... I need to know how to reproduce the bug, to fix it... Can you make a simple example and the steps to reproduce the issue? Davide edit: the problem occours when a variable is not defined/there's an error message thrown in the placeholder, I'll fix it ASAP. Edited by user 19 September 2014 20:14:54(UTC)
PLUGIN UPDATED SMath Studio 0.97.5346- Fixed critical bug on exceptions' propagation; - APIs updated; @brotjob: after updating the plugin, your file should be opened also without disabling auto-recalculation. Edited by user 19 September 2014 21:03:21(UTC)
on 19/09/2014(UTC), on 19/09/2014(UTC)
thank you for helping. The file can be opened again. Will test the new plugin version today.
There seems to be another issue with conditionally formatted labels:
- insert an area
- collapse the area
- insert a cfl below
- mark everything
- move everything
What happens is that the cfl does not move in relation to the rest. It can jump inside the area or just below the line of the collapsed area.
This seems a bug in the area region... 1) create a new worksheet 2) add an area region 3) collapse it 4) add a text region below the collapsed region, leaving a wide space. 5) select all (using the "select all" option or simply select the collapsed region and the text region) 6a) move all down a little using the mouse, and then do it again -> the space between the text region decreases progressively; when the text is close enough, goes inside the collapsed area region. 6b) move all up a little using the mouse, and then do it again -> the space between the text region decreases progressively and if you expand the area region, the size become larger at each movement; when the text is close enough, goes inside the collapsed area region. The size increase with absorption happens also if you select only the collapsed area. Both doesn't happens if you use the up/down keys or if the area is not collapsed. Added in the BTS: SS-221Edited by user 22 September 2014 13:11:50(UTC)
The new version disabled the feature if a ("true" "" "" ("false" "" "" I thought this is practical, why remove it? Now I have to use if a>0 ... Also, when I modify a sheet that was created with an older version of the plugin that uses the old style syntax and I adopt it to the new syntax, Smath Studio crashes. I will try without automatic recalculation now but my data is lost.
Hello brotjob, I cannot reproduce (or I've misinterpreted the issue) I see what is shown in the screenshot Davide Carpi attached the following image(s): |
Hi Davide First of all it's nice that you don't need the matrices anymore. Is there some kind of documentation of the plugin? I tried your above left example in a new worksheet->works perfectly. I change a to 1m ->label becomes red. I change if a to if a>0 ->smath crashes Edited by user 26 September 2014 12:10:47(UTC)
| Reason: got downgraded to older version when switching to portable version
Originally Posted by: brotjob First of all it's nice that you don't need the matrices anymore. Is there some kind of documentation of the plugin? Is a recent feature The official documentation is attached in the first post, moreover the Activebook of Martin Kraska contains a section for this plugin. Both should be updated, I'll do ASAP. Originally Posted by: brotjob I change a to 1m ->label becomes red. This is because the if statement doesn't support units as result of the condition argument. This is not in my hands. Originally Posted by: brotjob I change if a to if a>0 ->smath crashes I can't reproduce this issue, I'll investigate... |
Joined: 15/04/2012(UTC) Posts: 1,980 Was thanked: 1120 time(s) in 718 post(s)
Originally Posted by: w3b5urf3r_reloaded Originally Posted by: brotjob First of all it's nice that you don't need the matrices anymore. Is there some kind of documentation of the plugin? Is a recent feature The official documentation is attached in the first post, moreover the Activebook of Martin Kraska contains a section for this plugin. Both should be updated dexcription updated, please check. |
Originally Posted by: mkraska dexcription updated, please check. Thank you Martin, checked and solved a couple of minor issues (region disabled in the worksheet) Plugin UpdatedEdited by user 26 September 2014 19:01:13(UTC)
Documentation updated (see first post)
Originally Posted by: w3b5urf3r_reloaded Thank you Martin, checked and solved a couple of minor issues (region disabled in the worksheet)
Ok, thanks, I'll include that in the next update. |
Surprised I didn't know about this. This is great, thanks.
Originally Posted by: w3b5urf3r_reloaded Originally Posted by: mkraska dexcription updated, please check. The file is great but when I play with the sliders I every so often get a crash... Using plugin version 1.0.5382.30912 and current standalone Smath.
1 user thanked brotjob for this useful post.
Originally Posted by: brotjob The file is great but when I play with the sliders I every so often get a crash... Using plugin version 1.0.5382.30912 and current standalone Smath.
Confirmed. The post relates to this file |
