As for now, do not use this plugin for productivity Look in the attachment for details and features. SMath Studio 0.97.5301 or later requiredPLEASE REPORT HERE ANY ISSUEEdited by user 11 July 2014 01:13:24(UTC)
| Reason: Not specified File Attachment(s): Davide Carpi attached the following image(s): |
How about including unit-proof complex functions Re(), Im() and arg()? ( SS-24)? |
uploaded (big thanks to Andrey for the ultrafast bugfix ) Be sure to have the "Exclude beta-versions" unchecked Originally Posted by: mkraska How about including unit-proof complex functions Re(), Im() and arg()? ( SS-24)? Maybe in the Custom Functions as temporary patch (I prefer to have all the built-in functions unit-proofs, but I understand that this requires time) Best regards Davide Edited by user 11 July 2014 01:35:33(UTC)
| Reason: Not specified Davide Carpi attached the following image(s): |
on 11/07/2014(UTC), on 11/07/2014(UTC)
Hi, Can i suggest adding function to round calculated value to closest one of E-series (I'm talking about e.g. E96 series of resistors) ?
Regards Kriss
It looks like the plugin isn't working Or I am using it incorrectly?
Guess it is a bug. I'll check it ASAP. |
Seems that something is changed in SMath Studio, now overloads with definite and undefinite number of arguments are in a conflict state. As workaround in the dynamic assistant I've temporary removed the overloads with a single argument; you will still be able to use them and they will be the default when you insert one of the functions of the plugin (use tha argument separator key to add more arguments). I'll address the issue SMath side later. PLUGIN UPDATEDEdited by user 12 June 2018 12:03:40(UTC)
Um I'm a newbie but when I hit recalculate in that demo page the capacitance units get messed up.
By the way, how is the || operator typed in?
Thanks!
Originally Posted by: paltatech Um I'm a newbie but when I hit recalculate in that demo page the capacitance units get messed up. Confirmed, another thing to investigate. You can make it working removing the output unit customization on the rightmost placeholder. Originally Posted by: paltatech By the way, how is the || operator typed in? Type EEL_CPar( or EEL_RPar( and add 1 or more arguments with your argument separator key. |
The || tip worked right away, thanks!
Originally Posted by: paltatech when I hit recalculate in that demo page the capacitance units get messed up. Should be fixed now. PLUGIN UPDATED |
Joined: 01/04/2020(UTC) Posts: 85 Location: Wellington Was thanked: 4 time(s) in 3 post(s)
Originally Posted by: krissn Hi, Can i suggest adding function to round calculated value to closest one of E-series (I'm talking about e.g. E96 series of resistors) ?
Regards Kriss This could be very useful. There is an interesting solution for this here (used on my HP calculator): E24 Nearest Fraction Calculation. Thanks Takayuki HOSODA Edited by user 10 April 2022 02:30:10(UTC)
| Reason: Attribution
Hi. In the meantime, you can use this, but I didn't check it much so it may have some wrong values in the geometric series. ESeries.sm (14kb) downloaded 34 time(s).Best regards. Alvaro.
