I needed to write an interval in a text field using square brackets, which the program refused... [As You can see I can make them].
Is it possible to do this some other way?
I would also like to be able to assign value to a variable and on the same line print the result.
Example:
x:=2*5+9=19
Is this possible?
trucjensen wrote:I needed to write an interval in a text field using square brackets, which the program refused... [As You can see I can make them]. For me it is OK: trucjensen wrote:I would also like to be able to assign value to a variable and on the same line print the result. No, this is not implemented yet.
When I type the same thing in Notepad (I couldn't find a way to upload the screendumps):
These are square [brackets]
I get this result in Smath:
These are square brackets
I have tried on two different workstations (one with Windows XP - the other with Windows 7 installed) - both danish versions.
trucjensen wrote:When I type the same thing in Notepad (I couldn't find a way to upload the screendumps): myupload.dk trucjensen wrote:These are square [brackets]
I have tried on two different workstations (one with Windows XP - the other with Windows 7 installed) - both danish versions. Danish computer / keyboard here. Same error here. I can't make brackets in text fields o.0 Same error on laptop (Danish Keyboard too ...) Will try changing keyboard layouts EDIT: I set my keyboard to English (UK). Alas no help. I could reproduce brackets in notepad, but not smath (I hit the right keys :P) Edited by user 24 October 2009 16:32:56(UTC)
| Reason: Not specified
