6 Pages<1234>»
Offline Pablo001
#21 Posted : 29 January 2014 19:55:05(UTC)
Pablo001
Spain
Thank you, Davide. Good
Offline dyleks
#22 Posted : 04 February 2014 14:21:31(UTC)
dyleks
Poland
I have noticed that I can't install it in SMath version: 0.96.5146.
I am geting error: "Plug-in(s) installation failed."
And now every time i turn SMath Studio I have error:
"Error occured while trying to load third-party assembly. Pligin disabled."
Any idea ?
#23 Posted : 04 February 2014 14:29:22(UTC)
Was thanked: 1368 time(s) in 895 post(s)
This plugin is not yet available for SMath 0.96.5146
BTW any "Region" plugin that has the version scheme X.Y.####.Z, where #### is less than 5146 is not compatible with the latest nightly build.
Offline dyleks
#24 Posted : 04 February 2014 15:06:50(UTC)
dyleks
Poland
Thanks for explanation.
#25 Posted : 15 February 2014 03:35:43(UTC)
UPDATED
- SMath Studio 0.96.5146 or later required;
- heavy performances' optimization;
- added row/column limiters on data size change;
- customizable table outer borders;
- SMath Viewer compatible;
- fixes;
thanks 4 users thanked Davide Carpi for this useful post.
on 15/02/2014(UTC),  on 15/02/2014(UTC),  on 15/02/2014(UTC),  on 15/02/2014(UTC)
#26 Posted : 15 February 2014 15:17:40(UTC)
Thank you Ioan Good
Actually the "symbolic" representation is not implemented, any not numeric value is converted to a string, but this feature is in my plans.
[EDIT] I've updated again the plugin, there's a little fix for numbers formatting.
Edited by user 15 February 2014 22:27:19(UTC)  | Reason: Not specified
on 15/02/2014(UTC)
Offline Pablo001
#27 Posted : 15 February 2014 20:11:44(UTC)
Pablo001
Spain
Thank you Davide!!!! Good
#28 Posted : 15 February 2014 23:01:36(UTC)
You're welcome Good
BTW before releasing a "stable" version, I would like to have an opinion from the community whether it is preferable to have the header and footer areas extended to the stubs, or if it is better to leave them as they are Unsure
P.S. the latest update contains a bugfix about a border swap when the dialog is skipped
Offline mkraska
#29 Posted : 16 February 2014 00:37:37(UTC)
mkraska
Was thanked: 1153 time(s) in 739 post(s)
I wonder how you want to control cell alignment of the header if it extends over the stubs.
There are two features which might be adjusted a little (may be matter of taste):
- The cell dimensions are affected by settings of invisible parts. E.g. if left stub and data have their vertical padding set to zero (to get compact cells), then they still are adusted to the padding values of the right stub even if that is invisible.
- If the ellipsis is on the left side, then expanding the table to the right using the region markers is not possible (see image)
Did I get it right that the unit summary is for scaling the data by line?
BTW, I like the feature of getting rid of the region border. Would be fine for the image region as well.
Edited by user 16 February 2014 00:39:28(UTC)  | Reason: Not specified
#30 Posted : 16 February 2014 14:18:07(UTC)
Oh, that's a nice question, because I have absolutely no ideas about this, it's just a stone dropped in the pond Biggrin
Thank you (sizes balancing on invisible zones - fixed); I'm not sure if synchronizing vertical paddings we loose some features (when there are different font settings) so, as for now, I've left this untouched.
I'll think about this, actually I don't have ideas on how to handle by code the top/left resizing... as for now a way is to use "expand to table limits" feature and then, if needed, "shrink to page size"
By columns, by rows or global (single unit/scale factor)
[edit] attachment updated using the latest plugin's XML scheme
Edited by user 07 March 2014 13:55:06(UTC)  | Reason: attachment updated using the latest plugin's XML scheme
File Attachment(s):
units.sm (22kb) downloaded 81 time(s).
thanks 7 users thanked Davide Carpi for this useful post.
on 16/02/2014(UTC),  on 16/02/2014(UTC),  on 16/02/2014(UTC),  on 16/02/2014(UTC),  on 16/02/2014(UTC),  on 17/02/2014(UTC),  on 17/02/2014(UTC)
Offline mkraska
#31 Posted : 16 February 2014 15:33:09(UTC)
mkraska
Thanks, control by matrix dimension seems clean and easy to remember.
I'd prefer the unit summary entries not being converted to base units but rather being displayed as specified (perhaps with a bit of string processing to remove spurious curly braces and to replace ^2 by ³ and ^3 by ² )
There is, of course, a workaround by hiding the summary and writing the units as strings to the stub or header - with inherent danger of inconsistency.
I would like to add another feature request: formatting with specified number of significant digits.
File Attachment(s):
units.sm (24kb) downloaded 79 time(s).
on 16/02/2014(UTC)
#32 Posted : 16 February 2014 20:32:39(UTC)
I know... As I've written before, actually there's no way to do this directly...
This is possiblle, I'll do it.
Edited by user 17 February 2014 10:58:06(UTC)  | Reason: Not specified
Offline Infinity
#33 Posted : 18 February 2014 12:08:42(UTC)
Infinity
Rank: Member
Was thanked: 3 time(s) in 2 post(s)
I found two issues within this plugin.
- Comma ',' as argument separator does not work probably when sub matrices are used.
- The degree symbols causes issues when sub matrices are used.
Please see my attached images.
Best Regards,
Infinity
Infinity attached the following image(s):
thanks 1 user thanked Infinity for this useful post.
on 18/02/2014(UTC)
#34 Posted : 18 February 2014 16:44:56(UTC)
Thank you, I'll fix it Good
#35 Posted : 18 February 2014 18:56:19(UTC)
UPDATED
- changed XML read/save scheme (open and save again any existing file that contains tables)
- added significant digits settings;
- nested cells implementation improved;
- context menu resizing fixes & improvements;
- fixed issues when there are many variables with same name and different sizes;
- default position of units by rows now is on the right side;
- code fixes;
thanks 5 users thanked Davide Carpi for this useful post.
on 18/02/2014(UTC),  on 18/02/2014(UTC),  on 18/02/2014(UTC),  on 19/02/2014(UTC),  on 19/02/2014(UTC)
#36 Posted : 18 March 2014 02:52:13(UTC)
UPDATED
(SMath Studio 0.97.5189)
- code updated to fit the new APIs features;
- added SMath symbolic data representation.
Offline mkraska
#37 Posted : 20 April 2014 13:13:15(UTC)
mkraska
Happy easter to the smathicians!
Unexpected results in Table Region. All but the first submatrices are collapsed to some strange number. Something went wrong...
File Attachment(s):
NK TM1 13.sm (39kb) downloaded 80 time(s).
on 21/04/2014(UTC)
#38 Posted : 21 April 2014 20:38:50(UTC)
Thank you Martin, bug added in the BTS (SS-120)
Best regards,
Davide
on 21/04/2014(UTC)
Offline mkraska
#39 Posted : 21 May 2014 00:24:08(UTC)
mkraska
Here is another small problem with nested matrices. I added this to BTS issue SS-120.
on 21/05/2014(UTC),  on 24/05/2014(UTC)
Offline Alex M.
#40 Posted : 01 December 2015 22:32:31(UTC)
Alex M.
Davide,
Do you anticipate any future work on allowing to use Table Region to define a matrix?
This could work extremely well with my excel_IO plugin.
If not, can I play with your code to see what I can do to fit my needs?
What I envision is:
i. Use your table region to create matrix of a following format:
1st row - EXCEL row i.d. (A,B,C...)
1st column - EXCEL column i.d. (1,2,3...)
other rows/columns - input data
ii. Use my excel_IN function to pass cell input values and addresses to excel process
iii. Use my excel_PNG function to display any changes in excel worksheet in real time
iv. Use my excel_OUT function to dynamically output data from excel process
Thanks!
Similar Topics
Table Region Problem (Questions)
by ndtma 27/08/2023 11:58:19(UTC)
[Table Region] Caption Font Size Problem with Windpws Display Scale (Bugs & Problems)
by ndtma 09/01/2022 20:02:03(UTC)
Text formatting single cell in table region (Questions)
by wb.c 15/09/2021 22:14:25(UTC)
Table Region PlugIn (Questions)
by MBernacca 29/01/2020 13:42:47(UTC)
"Table Region" Plug-in installation failed (Questions)
by aviateCar 02/07/2019 23:30:54(UTC)
Table Region Font Bug at Font Scale %125 (Bugs & Problems)
by overlord 16/03/2019 23:00:46(UTC)
Show the Orignal Units in Table Region (Questions)
by CBG 21/03/2018 22:01:53(UTC)
by CBG 07/03/2018 20:21:01(UTC)
Table Region Units (Extensions)
by CBG 16/12/2017 04:41:33(UTC)
Table Region Model (Samples)
by Jean Giraud 07/06/2017 18:19:06(UTC)
6 Pages<1234>»
