3 Pages123>
Offline uni
#1 Posted : 29 April 2013 03:38:19(UTC)
uni
Was thanked: 1400 time(s) in 817 post(s)
3D Plot Region
SMath Studio compatibility SMath Viewer compatibility mono compatibility Extension page Sources
Regions: 3D Plot.
Functions: CreateMesh().
Edited by user 07 May 2020 22:36:01(UTC)  | Reason: Not specified
File Attachment(s):
3D Plot. CreateMesh. Examples.zip (191kb) downloaded 671 time(s).
Russia ☭ forever (git.io/vOZo0)
Viacheslav N. Mezentsev
thanks 5 users thanked uni for this useful post.
on 29/04/2013(UTC),  on 29/04/2013(UTC),  on 29/04/2013(UTC),  on 29/04/2013(UTC),  on 17/01/2016(UTC)
Offline mkraska
#2 Posted : 03 May 2013 22:12:32(UTC)
mkraska
Looks promising!
In particular I like the right-handedness of the plot.
Issues:
- IsVisible attributes of axesstyle and gridstyle are not responsive.
- strange behaviour if z limits are exceeded by the z-surface. I guess that the surface should be trimmed by the bounding box. Otherwise the axes have to be included in the hidden line algorithm. For now you seem to assume that they are always in the background.
- definition of a function is mandatory. No pure xy-expressions.
on 03/05/2013(UTC)
Offline uni
#3 Posted : 03 May 2013 23:51:14(UTC)
uni
Yes, I know about all these problems. They are based on the library that I used. I'm working on that too.
Let's imagine the xy-expression: 1 + x*y + 3*(x-y)+ sin(t0) -> 1 + x[1]*x[2] + 3*(x[1]-x[2])+ sin(t0) or 1 + x[2]*x[1] + 3*(x[2]-x[1])+ sin(t0) ?
Unlike X-Y Plot we have two independent variables. How do I know their order (x,y) or (y,x)? That's why it is not implemented in Mathcad too. I don't want use only x and y variables for that purpose.
Offline omorr
#4 Posted : 04 May 2013 00:09:44(UTC)
omorr
Serbia
Was thanked: 319 time(s) in 268 post(s)
It seems that you can delete the function name "f" from the placeholder and to put something else. It will keep the previous function and not complaining.
Offline mkraska
#5 Posted : 04 May 2013 00:40:00(UTC)
mkraska
OK, clearyl I have to accept and respect your preferences, but I would not mind x and y being used as dummy variables just like in the built in 3D graphics region. That may, of course, be limited to cases, where there is no pure function name given.
Assigning the x-axis to the first and the y-axis to the second argument of the plot function prevents the user from plotting f(y,x) instead of f(x,y). If you want to be free to avoid the look of x and y in the placeholder, then you still can assign x and y to other names. You even could get the names as smart defaults for axis labels.
The freedom in variable choice in the xy-plot is obtained at the price of having to keep these variables unassigned above that plot. Even Davide's Clear won't help (I tried that).
Edited by user 04 May 2013 00:42:20(UTC)  | Reason: Not specified
Offline uni
#6 Posted : 04 May 2013 00:52:31(UTC)
uni
I can do this:
1. If you enter a function f(2) then I think it equal to f(x, y)
2. If you enter a function f(1) then I think it equal to f(x[1],x[2]), where x - vector ([x,y]).
3. If you enter a simple expression and it has one undefined variable, then I think it is a vector ([x,y]).
Offline mkraska
#7 Posted : 04 May 2013 01:21:20(UTC)
mkraska
Never mind! I shall cope...
Offline kilele
#8 Posted : 04 May 2013 02:49:36(UTC)
kilele
Was thanked: 133 time(s) in 114 post(s)
uni, i don't know if you could take advantage of this code:
http://www.codeproject.c...performance-WPF-3D-Chart
on 04/05/2013(UTC)
Offline uni
#9 Posted : 04 May 2013 02:56:34(UTC)
uni
Yes, it's interesting, I added to my bookmarks. I have an account on codeproject.
There is another similar things: Plot 3D surfaces.
Offline kilele
#10 Posted : 04 May 2013 11:51:20(UTC)
kilele
BTW, the author of the book you mentioned in the xyplot thread, has another book about WPF
"Practical WPF Charts and Graphics"
Offline uni
#11 Posted : 08 May 2013 00:44:23(UTC)
uni
Updated. Function CreateMesh() moved from the Plot3D plugin. Do not use it any more.
Offline mkraska
#12 Posted : 08 May 2013 01:07:09(UTC)
mkraska
Thanks for the update. I installed the updated version and removed Plot3D.
now the 3DPlotRegion plugin shows up twice in the plugin manager, see attached screenshot.
Edited by user 08 May 2013 01:11:07(UTC)  | Reason: Not specified
Offline uni
#13 Posted : 08 May 2013 01:46:03(UTC)
uni
Don't worry, this is normal. Andrey will correct it.
Offline kilele
#14 Posted : 09 June 2013 15:00:54(UTC)
kilele
I mentioned this resource in another thread.
These are some c# wrappers for VTK:
http://www.vtk.org/Wiki/VTK/CSharp/ActiViz.NET
http://vtkdotnet.sourceforge.net/
Offline kilele
#15 Posted : 09 June 2013 15:01:26(UTC)
kilele
I mentioned this resource in another thread, VTK.
These are some c# wrappers for VTK :
http://sourceforge.net/projects/vtknetexamples/
Edited by user 09 June 2013 17:47:45(UTC)  | Reason: Not specified
on 09/06/2013(UTC)
Offline mkraska
#16 Posted : 18 June 2013 16:02:12(UTC)
mkraska
I am using the plugin from the extension manager.
Seems that I can now save the regions, but user settings aren't saved (see attached sheet, where the default settings are not really appropriate).
Is that a local problem or known bug?
Uni, are you going to continue this branch of plotting or do you focus on other ways?
File Attachment(s):
NelderMead.sm (30kb) downloaded 172 time(s).
Offline mkraska
#17 Posted : 01 February 2014 22:37:28(UTC)
mkraska
CreateMesh() is useful for 2D plots as well...
on 02/02/2014(UTC),  on 02/02/2014(UTC)
Offline mkraska
#18 Posted : 02 February 2014 13:54:16(UTC)
mkraska
In the previous version, the expression to plot had to be an explicitly defined function. This condition is now relaxed thanks to Davide's FunctionsExtensions plugin. Using the at(expr,var) function, you can substitute values for undefined variables in arbitrary expressions, thus you can use these expressions as if they were functions.
Uni, if you would make CreateMesh() flexible in that it can handle 2- and 3-element vectors, then poking out the submatrix in the 2D case would not be required any more.
File Attachment(s):
mesh.sm (5kb) downloaded 112 time(s).
Offline mkraska
#19 Posted : 04 March 2014 20:58:30(UTC)
mkraska
The current version (0.1.5161.27307) of the 3DPlot plugin interferes with the clipboard. If pasting any expression from the clipboard to the canvas, I get a 3DPlot region instead. There used to be a similar problem with Hyperlink and Conditionally formatted labels, Davide managed to handle this.
Offline hpf_br
#20 Posted : 23 March 2014 17:12:58(UTC)
hpf_br
Rank: Member
Brazil
Is it possible to use augment(u;v;f) on 3DPlot plugin, like we use on a X-Y Plot plugin? (u;v;f are vectors).
File Attachment(s):
rod_spring.sm (33kb) downloaded 175 time(s).
Similar Topics
3D Plot Region (Chart3DLib) (Bugs & Problems)
by Dariusz Pogocki 05/10/2020 04:05:04(UTC)
3 Pages123>
