Originally Posted by: mkraska I always use my x64 Win7 notebook. I had very severe problems when trying your files at work. Now at home (same computer), I cannot reproduce them, except the StdDev issue with Maxima sum. I saw rubbish error messages containing §§ characters. Have no idea what is going on??? Here is what happened on my x64 Win7 notebook Maxima load()I can not see any pattern here, sometimes recalculating many times worked fine and once or twice failed. Sometimes every few calculations it fails. Regards, Radovan Edited by user 26 November 2013 12:10:06(UTC)
There may be issues with the socket connection, Kay will have a look at these problems. Stabilizing is on top of our agenda. |
Here are some examples, showing the following issues: - how to create log plots
- how to perform a nonlinear least square fit
- how to work around translation problems. Currently, no nested lists and no mixed list and matrix arguments are allowed.
The trick with mixed and nested arguments is to define them step by step as Maxima variables. Please note that you must kill such variables before you can re-define them. EDIT: HV_WEZ.prn data file added (zipped, because prn files are not allowed as attachments). Edited by user 27 December 2013 23:24:32(UTC)
| Reason: Not specified File Attachment(s): mkraska attached the following image(s): |
Hello Martin, The file "HV_WEZ.prn" is missing here and there are errors in "HV_WEZ_lsquares.sm". Could you add this file please. I just tried with some random data, sometimes partially worked sometimes not. There are some "empty stack" errors and I just wanted to check this with your file or the data matrix you used. Regards, Radovan Edit: I manage somehow to use the data from your plot just randomly, and it seems to work. Very nice Still, I do not know what those "stack empty" mean By the way, it seems that you manage that we can resize the plots now? As I remember it was not possible before Edit2: Ah yes, I can see you added the data - thank you Edited by user 27 December 2013 23:45:11(UTC)
Sorry, I forgot the datafile, it is now added. The fitting procedure is not really robust, thus it may fail easily when the data is changed or the initial values are to far off. empty stack errors result from back-translation problems (if the result contains nested lists), yet the maxima commands work. Resizing the images works for images created with the standard gnuplot interface of Maxima, images generated with the draw package still cannot be scaled (did not yet find the right settings). Edited by user 28 December 2013 01:29:35(UTC)
Originally Posted by: mkraska Resizing the images works for images created with the standard gnuplot interface of Maxima, images generated with the draw package still cannot be scaled (did not yet find the right settings). Ah yes, you are right. Did not pay attention, sorry. Here are some examples with draw package Regards, Radovan Edited by user 28 December 2013 10:08:03(UTC)
from the gnuplot examples pageFile Attachment(s): mkraska attached the following image(s): |
From the gnuplot examples page EDIT: file corrected Edited by user 03 January 2014 11:46:51(UTC)
2 users thanked mkraska for this useful post.
on 03/01/2014(UTC), on 03/01/2014(UTC)
Thank you Martin, I did not have a success for this example. Here is the log file. I suppose the problem is in the international settings (coma, semicolon etc.) Regards, Radovan Edited by user 03 January 2014 09:47:11(UTC)
I uploaded the wrong version of the file, corrected now. Lists as function arguments seem to have some complexity limit. Inspection of the log file shows that the translator re-uses the strings from the preamble list in the right hand sides of other options, where expressions are expected, not strings. I don't know if there is a quick fix. In the meantime, we either have to limit the complexity or to define Maxima variables. You can assign the previous expression to a variable l by Maxima("$l:%$" ) Edited by user 03 January 2014 12:23:49(UTC)
Yes it is Ok now. Thank you Regards, Radovan |
Example for linear programming and plotting File Attachment(s): mkraska attached the following image(s): |
This was nice as well, thank you By the way, I tried most of the stats hypothesis testing functions and they work by following your example how to do that. One of them did not work regarding simple linear regression. Here are the test file and the log file as well. From the debug window I had the impression that the calculations performed well, but there is no SMath output (again "stack empty" error). Regards, Radovan File Attachment(s): omorr attached the following image(s): |
There seems to be a problem with display of functions with list arguments. In the given case, you can avoid the function in the output by wrapping it in args(), which returns a list of the function arguments. The outer mat2sys is just for cosmetic reason. I just prefer that type of results being left justified. Make sure to set optimization None in the function call and in results display to get float results. Opt numeric won't work due to the texts being bare variable names. It seems that the functions are capable of handling matrices. File Attachment(s): mkraska attached the following image(s): |
Unfortunately, it does not work for me. I can not use matrices here, therefore I defined it in Maxima with Maxima( "$ $" ). If I use a matrix like you did with matrix M, the error message in the debug window appeared " apply: second argument must be a list; found: M #0: simple_linear_regression(dat=M,select=[conflevel = 0.99]) -- an error. To debug this try: debugmode(true); (%i7) " Moreover, when I use the same command as you did, no result - stack empty again, although still look that the result is here - see the log file please. Regards, Radovan Edited by user 03 January 2014 21:00:39(UTC)
The problems seem to be arg/dec separator related. I can reproduce a crash with my file. It occures in the back-translation step. This is definitely a bug with little chance of fast fixing (Kay has to focus on exam session). What puzzles me is that the error message refers to the second argument. In the call, M is (should be) the first argument. If you still want to go on testing, then as a workaround you might extract individual elements of the solution. Could you please try that? If that works, then the matrices should not be an issue. Could, however, be a Maxima version issue (newer versions might be more picky about argument type than mine). I still use 5.31.1-1. Edited by user 03 January 2014 23:16:10(UTC)
| Reason: Not specified mkraska attached the following image(s): |
I use the same Maxima version as you do 5.31.1-1. I am really puzzled that whatever works for you in this example, it does not work for me. I just tried and again here are the two pictures with matrices M defined in two ways and their respective logs - with errors. I also noted that matrix M is referred as second argument? Have no idea what that might be. I alo tried to change the arg/dec into coma and semicolon - no sucess. If there is anything else I could try regarding this - just let me know. Otherwise, we can just wait for Kay Regards, Radovan Edited by user 04 January 2014 00:45:33(UTC)
| Reason: Not specified omorr attached the following image(s): |
I think there are two problems: 1. If in the debugger, you have to set the preprocessing flag. Otherwise M is not replaced by it's symbolic contents. The dialog is obscured by the log but I would bet a pivo that you did not set the flag ;-) 2. You applied the second el() function to the index 2, not to the complete expression. You want the first list from the result structure. I admit, that this was not obvious from the screenshot. Removing the debug flag from the Maxima call and correcting the el function should do the job. mkraska attached the following image(s): |
Example plots from the drawdf package documentation. This package provides functions for direction field plots. The sheet is tested with ;, and ,. arg and dec separator settings. File Attachment(s): mkraska attached the following image(s): |
Originally Posted by: mkraska 1. If in the debugger, you have to set the preprocessing flag. Otherwise M is not replaced by it's symbolic contents. The dialog is obscured by the log but I would bet a pivo that you did not set the flag ;-) You definetelly won a pivo (more than one actually rinks: ). Originally Posted by: mkraska 2. You applied the second el() function to the index 2, not to the complete expression. You want the first list from the result structure. I admit, that this was not obvious from the screenshot.
You are right again, my mistake sorry. Here is the screenshot. If I understood you well, the complete calling of the entire system here is problematic - maybe a bug (sometimes it crashed for me as well) but it can be done by calling one by one - like in the picture. Regards, Radovan Edited by user 04 January 2014 11:38:00(UTC)
