5 Pages123>»
#1 Posted : 30 September 2013 17:46:40(UTC)
Was thanked: 1396 time(s) in 910 post(s)
SMath Studio compatibility SMath Viewer compatibility mono compatibility
extension page Sources MIT license
Hi all,
Here there is a plugin to add labels customizable by canvas inputs.
Plugin languages: English Italiano
  • requirements: SMath Studio 0.96.5146 Nigthly build or later, .Net Framework 2.0;
  • installation: SMath Studio: Tools > Plugins... > Online Gallery;
  • documentation: download and unzip the attached archive;
  • languages: if you want to have a new UI language look into the documentation's Language folder
>>> PLEASE REPORT IN THIS THREAD ANY ISSUE, MORE DETAILED AS POSSIBLE <<<
Control Regions: CheckBoxList | ComboBoxList | ConditionallyFormattedLabelNumericUpDown | PathPicker | RadioButtonList | Slider
Edited by user 01 November 2021 13:34:12(UTC)  | Reason: Links
File Attachment(s):
CFLabelRegion_docs.7z (84kb) downloaded 796 time(s).
thanks 7 users thanked Davide Carpi for this useful post.
on 30/09/2013(UTC),  on 30/09/2013(UTC),  on 30/09/2013(UTC),  on 30/09/2013(UTC),  on 01/10/2013(UTC),  on 26/10/2013(UTC),  on 16/12/2015(UTC)
Offline omorr
#2 Posted : 30 September 2013 18:28:24(UTC)
omorr
Serbia
Was thanked: 319 time(s) in 268 post(s)
This is nice Davide, thank you Good
By the way, we can suppress viewing the if statement (only the formated label) by right click and unchecking "Display input data"
#3 Posted : 30 September 2013 19:30:11(UTC)
You're right Radovan, and you can also nest many if/else to have multiple outputs Good
Offline PompelmoTell
#4 Posted : 30 September 2013 20:28:28(UTC)
PompelmoTell
Was thanked: 110 time(s) in 94 post(s)
thanks Davide,
but I can't resize the label despite the presence of grip
Win64
Portable Version Smath 0.96 (build 4909)
Offline mkraska
#5 Posted : 30 September 2013 21:12:09(UTC)
mkraska
Originally Posted by: PompelmoTell Go to Quoted Post
thanks Davide,
Win64
The size is exclusively driven by the contents (string length). Might be a good idea to hide the grips.
Please find attached a brick for bar charts. Please note that I was forced to fill the right of the bar by visible symbols as spaces obviously are disregarded for computing the region size.
File Attachment(s):
Example cfregion barchart.sm (5kb) downloaded 216 time(s).
on 30/09/2013(UTC)
#6 Posted : 30 September 2013 21:39:22(UTC)
Correct, this is by design - like for hyperlink regions Good
I know, but is not yet possible; Andrey know this issue, the behavior will change in future
I can force the plugin to measure also the trailing spaces, if could be useful, just let me know it Good
best regards,
Davide
2013-09-30 20_38_18-SMath Studio Desktop - [Example cfregion barchart.sm].png
on 30/09/2013(UTC)
#7 Posted : 30 September 2013 22:04:25(UTC)
Done, updated
on 30/09/2013(UTC)
Offline mkraska
#8 Posted : 30 September 2013 22:38:42(UTC)
mkraska
Now the complete bar chart.
File Attachment(s):
Example cfregion barchart.sm (28kb) downloaded 143 time(s).
on 01/10/2013(UTC),  on 01/10/2013(UTC)
#9 Posted : 01 October 2013 17:08:16(UTC)
UPDATED
- works in Smath Viewer;
- default background color (empty string): white;
- default foreground color (empty string): black.
Edited by user 01 October 2013 18:03:35(UTC)  | Reason: Not specified
on 02/10/2013(UTC)
Offline mkraska
#10 Posted : 02 October 2013 11:22:38(UTC)
mkraska
Thanks for the update.
As you see, the region can display multiline text, thus it would be possible to do stuff like the bar chart in a single region, if there was access to the newline character from the GUI.
I'd propose to accept a single string as argument, now as there are defaults for the colors.
I also propose to left align the text (or to provide optional control)
#11 Posted : 02 October 2013 11:43:53(UTC)
Hi Martin,
I see, I'll think about to add more controls... as general idea this region is thinked to be used as a label (a short text) with variable appearance depending on the script events; the table region will be the better solution to have a more customizable (fixed) appearance. Good
BTW your last example puts me in mind that would be more handy and useful to use the built-in Output window to easily access these infos without calling dedicated functions or looking for log files.
Edited by user 02 October 2013 11:48:56(UTC)  | Reason: Not specified
Offline mkraska
#12 Posted : 02 October 2013 13:05:31(UTC)
mkraska
Off-spec use of features is part of the fun, isn't it?
I suppose your proposal impies that the output window can be fed directly from inside plugins. How would I trigger this from outside? How do I identify the output of a particular math region in the midst of a SMath sheet? I can't stop the re-calculation of a sheet at a particular expression, can I?
The maxima plugin has a two-level log inspection feature:
  1. MaximaLog("all" ) displays the entire Maxima session from the Maxima perspective without translation detail)
  2. MaximaLog(#) displays the detail of the previous Maxima call including maxima command, maxima response and back-translation.
By positioning the MaximaLog(#) at the right place you can clearly tell what Maxima did in the last interaction, regardless if the call was made by a hijacked function like int(), diff(), sum() or lim(), a dedicated function like Solve() or LinSolve() or directly by a Maxima() command.
I found MaximaLog(#) handy to use for documenting bugs in the todo list and it is always close at hand (from the dynamic assistant) in the sheet without the need to open and close the output window.
I must admit that I don't know how to even reach this level of comfort and clearness using the output window. How would you control the output if not by dedicated commands? How would you identify where the output came from? When using trace(), I find myself adding label texts to output commands in order to match the output with the SMath context. But I may just oversee options, thus any ideas are welcome.
#13 Posted : 02 October 2013 13:35:07(UTC)
Not always (for the developpers) Tongue
The multiline feature is not easily accessible from the canvas, so the alignment feature would produce confusion (in some way like the resize's grips); BTW if you want a "display region" to send out a well formatted output from the Maxima plugin, you can also make something like the "Maple" region of Viacheslav Wink
Sincerely I don't know, I've threw a stone into the pond Good
Maybe a special context menu item could be added or a log function with canvas free result that enable the output window output, or something else Good
BTW looking back my previous post Log files are useful for crashes (deep debugging -> plugin's developpers)
Edited by user 02 October 2013 15:26:55(UTC)  | Reason: Not specified
#14 Posted : 04 October 2013 22:16:41(UTC)
UPDATED
- Fixed regional settings issues with Font sizes (comma decimal separator related*)
* Martin's activebook svn file updated
on 04/10/2013(UTC)
Offline mkraska
#15 Posted : 04 October 2013 22:35:37(UTC)
mkraska
Great, thanks. I also updated the barchart example.
#16 Posted : 25 October 2013 18:39:06(UTC)
UPDATED
- small fixes
- added styles (optional 4th argument)
on 26/10/2013(UTC)
#17 Posted : 03 February 2014 02:56:29(UTC)
UPDATED
- SMath Studio 0.96.5146 required
best regards,
Davide
on 03/02/2014(UTC),  on 03/02/2014(UTC)
Offline kaaden
#18 Posted : 05 February 2014 11:22:07(UTC)
kaaden
Rank: Member
Spain
Hello !
Where can I download the Formatting Label for 4909 versión?
with new version I can´t open old snippets
#19 Posted : 05 February 2014 11:46:51(UTC)
Originally Posted by: kaaden Go to Quoted Post
Hello !
You can use the portable version provided by mkraska (here) directly or copying the plugin from that distribution to your %APPDATA% folder
Edited by user 05 February 2014 11:55:11(UTC)  | Reason: Not specified
Offline kaaden
#20 Posted : 05 February 2014 12:18:01(UTC)
kaaden
Rank: Member
Spain
thanks
I download from here
http://smath.info/wiki/SMath%20with%20Plugins.ashx
Edited by user 05 February 2014 12:20:13(UTC)  | Reason: Not specified
Similar Topics
Conditionally Formatted Labels vs Insert Writer Region (Questions)
by Fran_3 11/11/2021 20:27:23(UTC)
5 Pages123>»
