3 Pages123>
#1 Posted : 05 November 2012 14:30:15(UTC)
Was thanked: 1396 time(s) in 910 post(s)
Hi all,
Just a seed for statistical purposes Happy
Plugin handles primitives listed below:
Sample Estimators
Probability Density Functions
Cumulative Density Functions
Quantile functions
Random Numbers
Tools
PLEASE REPORT HERE ANY ISSUE.
requirements: .Net Framework 3.5 (Windows) / Mono 2.0 (Linux) / SMath Studio 0.97.5581
installation: Tools > Plugins > change "Local Storage" to "Online Gallery" > Statistical Tools
sources: if you want to see the plugin sources, look in the SVN repository.
embedded plugins: Meta Numerics library 2.2.1.0 (website, license)
Edited by user 15 September 2015 16:31:42(UTC)  | Reason: Meta Numerics
File Attachment(s):
StatisticalTools_docs.zip (35kb) downloaded 491 time(s).
on 05/11/2012(UTC)
Offline omorr
#2 Posted : 05 November 2012 15:01:07(UTC)
omorr
Serbia
Was thanked: 319 time(s) in 268 post(s)
Hello w3b5urf3r,
I remained almost speechless by seeing this Dance Biggrinancing: Biggrinrinks: Shok
Have no words to express my gratitude for this plugin Thank you
Just hope that the inverse cumulative distributions would be applied as well.
Just one suggestion if you would not mind. There is a naming convention in Mathcad and R ("lingua franca" for statistics).
pdf (probability density starts with d - like dnorm)
cdf (cumulative probability function starts with p - like pnorm)
inverse cdf (inverse cumulative probability function starts with q - like qnorm)
random numbers from a distribution starting with r - like rnorm
EDIT: Maybe redundant to say, but besides normal there are t-student, chi-squared and F which are "must have" continuous distributions.
Edited by user 05 November 2012 16:02:17(UTC)  | Reason: Not specified
on 06/11/2012(UTC)
Offline mkraska
#3 Posted : 05 November 2012 22:08:53(UTC)
mkraska
Hello w3b5urf3r,
thank you for the great work. I just got one question. As far as I understand, the Mode function gives the value (or a vector of values) with the highest number of occurences in a dataset.
Then, in the following the result should be a vector of (1 2 3 5) with 4 occurences.
Mode(mat(1,3,5,1,6,2,3,2,5,2,3,5,5,2,1,3,4,1,3,6),1)=mat(mat(5,1,1),mat(2,1,1),2,1)@#
Best regards, Martin
BTW, I like the smart handling of vector arguments in functions!
Edited by user 05 November 2012 22:12:09(UTC)  | Reason: Not specified
#4 Posted : 06 November 2012 02:17:40(UTC)
Hello w3b5urf3r,
Thank you Martin, I've lost 2 lines of code cleaning the sources...
fixed & updated Good
best regards
w3b5urf3r
Offline mkraska
#5 Posted : 07 November 2012 02:23:55(UTC)
mkraska
Hello w3b5urf3r,
some minor doc issues:
in pdf.sm, the doc for pdf.uniform needs a little correction:
f(x,a,Cool:line(if(a>b,line(swap:a,a:b,b:swap,3,1),0),if((x≥a)&(x≤Cool,1/{b-a},0),2,1)
Also, the pdf.Rayleigh(2) and cdf.Rayleigh(2) help strings seem to have a copy-paste error.
Edited by user 07 November 2012 18:45:38(UTC)  | Reason: Not specified
Offline omorr
#6 Posted : 07 November 2012 12:03:45(UTC)
omorr
Serbia
Hello w3b5urf3r,
I would kindly ask you to insert into this plugin at least intercept(x,y) and slope(x,y) functions for calculating the least square intercept and slope of a straight line giving two data vectors.
Edited by user 07 November 2012 12:05:52(UTC)  | Reason: Not specified
#7 Posted : 08 November 2012 17:36:35(UTC)
Originally Posted by: omorr Go to Quoted Post
Hello w3b5urf3r,
Ok Biggrin .
Hello w3b5urf3r,
Done, will be available in the next relase Good .
regards,
w3b5urf3r
Edited by user 08 November 2012 19:12:21(UTC)  | Reason: Not specified
on 08/11/2012(UTC)
#8 Posted : 02 December 2012 15:07:42(UTC)
PLUGIN UPDATED
- added more tools: Regularized Beta function, Regularized Gamma functions (P and Q), Ceil, Floor, error function, inverse error function;
- added more estimators: Kurtosis, Kurtosis Excess, Moment, Skewness, Intercept, Slope;
- added more probability distributions: Student's t, Fisher-Snedecor, Chi-squared, Cauchy;
- added quantiles (all distributions except Student's t, Fisher-Snedecor and Chi-squared).
best regards,
w3b5urf3r
Edited by user 02 December 2012 16:48:06(UTC)  | Reason: Not specified
on 02/12/2012(UTC)
Offline omorr
#9 Posted : 02 December 2012 21:43:33(UTC)
omorr
Serbia
Hello w3b5urf3r,
Many thanks for this plugin Good .
Just played a bit, and have seen a problem with CDF.ChiSquare( "variable" )-(image attached). Did not quite understand why this problem appear at the moment. Also, do not quite understand what this description mean
CDF.ChiSquare( "variable" ) - Returns the Χ² sDOF CDF evaluated in "1:variable" points.
I suppose that sDOF means "single degree of freedom"
Edited by user 02 December 2012 21:45:16(UTC)  | Reason: Not specified
on 08/12/2012(UTC)
#10 Posted : 02 December 2012 23:02:26(UTC)
Hello w3b5urf3r,
Biggrin seem that some eval() in the Reguarized Gamma functions it's stricly necessary for some value.... fixed and updated Wink
You supposed right Tongue Now I've extended the acronym Wink
EDIT: plugin updated again (Mean and StdDev names)
regards,
w3b5urf3r
Edited by user 03 December 2012 02:53:14(UTC)  | Reason: Not specified
StatisticalTools plugin - Samples - SMath Studio Forum - Mozilla Firefox.png
on 03/12/2012(UTC)
Offline omorr
#11 Posted : 03 December 2012 11:21:12(UTC)
omorr
Serbia
Hello w3b5urf3r,
I wonder why all of the functions inside plugin are not in a separate function category. They are inside "Matrix and vector" function category now.
Not so important at the moment, I am just curious Good
P.S. I am looking forward to the missing ICDF's Good Thank you
#12 Posted : 03 December 2012 13:14:54(UTC)
Hello w3b5urf3r,
Hi omorr,
I'd like to put them in a new category "Statistics" but I do not know if it is possible to expand the available categories through the plugin. Because all functions accept a vector as input i've grouped all as "matrix and vector".
About the missing ICDF I'm looking for a fast and accurate algorithm to compute each of them... if I find anything I will use a bisection algorithm Good
regards,
w3b5urf3r
on 03/12/2012(UTC)
Offline turducken
#13 Posted : 07 February 2013 22:16:18(UTC)
turducken
Will this plugin eventually have the ability to produce a random number from a normal or Gaussian distribution (rather than uniform distribution)?
I would be using this to create random white Gaussian noise to simulate measured/actual situations. For instance, Mathcad has the function rnorm() that does this.
Thank you, and I greatly appreciate SMath and am looking forward to transitioning to it once I understand it has all the capabilities I need.
#14 Posted : 08 February 2013 13:50:45(UTC)
Sure, soon or later... Good
best regards,
w3b5urf3r
#15 Posted : 04 June 2013 09:51:08(UTC)
A Nightly update for anyone are using SMath Studio 0.96.4902 (plugins -> online gallery) and for anyone are using the previous SMath Studio relases (1st post).
- improvements of existing Random() functions (seed issues)
- Added a Guid (after the download an error should appear using worksheets created with the old plugin, just continue and save again the file)
- Sources are moved to the SVN server (there is a link in the first post)
best regards,
w3b5urf3r
Edited by user 04 June 2013 13:44:06(UTC)  | Reason: Not specified
on 04/06/2013(UTC)
Offline mkraska
#16 Posted : 03 September 2013 16:20:39(UTC)
mkraska
There is a problem with plotting the Gamma function, see attachment. Might be an issue of plotregion rather than Statistical tools...
Edited by user 03 September 2013 16:23:36(UTC)  | Reason: Not specified
File Attachment(s):
Gamma.sm (9kb) downloaded 93 time(s).
#17 Posted : 03 September 2013 17:13:12(UTC)
Gamma(1) is a built-in function, don't know what's the issue No
on 03/09/2013(UTC)
Offline mkraska
#18 Posted : 03 September 2013 18:59:58(UTC)
mkraska
Sorry, I was tricked by the capital letter...
One more reason to mention the plugin in the description string in order to avoid such confusion. Sometimes I check plugin origin of a given function by switching off the guessed one and trying if I still get the function. As that is not really handy, I tend to be lazy just like in the given case :-(
#19 Posted : 15 September 2015 11:52:13(UTC)
PLUGIN UPDATED SMath Studio 0.97.5581
  • .NET Framework 3.5 required;
  • (SS-91) Added missing quantiles (Chi Square, Student's t, F) using the Meta Numerics library 2.2.1.0 (website, license);
  • erf, erfc, erfinv from Mata.Numerics;
  • minor code changes;
Edited by user 15 September 2015 11:57:06(UTC)  | Reason: Not specified
on 15/09/2015(UTC)
Offline omorr
#20 Posted : 15 September 2015 19:32:05(UTC)
omorr
Serbia
Thank you Davide,
At last...long awaited quantile functions Good
Best Regards,
on 16/09/2015(UTC)
3 Pages123>
