UPDATED- command-line options syntax: 'ProcessToStart'[space]Flags[edit] - Graphical adjustements Edited by user 24 August 2013 01:06:25(UTC)
| Reason: Not specified Davide Carpi attached the following image(s): |
Joined: 15/04/2012(UTC) Posts: 1,980 Was thanked: 1120 time(s) in 718 post(s)
Thanks for the fast reaction. Hyperlink is simply great. I find myself launching applications using Ctrl-H "command +Click |
UPDATEDJust to complete the early introduced feature - converter on paste accept command-line strings (input string: "ProcessToStart"[space]Flags) so when you paste in the placeholder something like: Code:"C:\Windows\system32\rundll32" sysdm.cpl,EditEnvironmentVariables
this will become: Code:"'C:\Windows\system32\rundll32' sysdm.cpl,EditEnvironmentVariables"
best regards, Davide Edited by user 26 August 2013 21:16:36(UTC)
Strange bug: If you copy a Hyperlink region with description using Ctrl-Drag, then both original and copy seem to use the same data. If you edit the copy, the original changes as well (also the cursor is shown there). Playing around with empty/nonempty or visible/nonvisible description prior to copying shows other glitches like frozen box size in the copy description. That might be secondary symptoms of the data handling problem. If you copy using Ctrl-C Ctrl-V everyting is fine. Edited by user 28 August 2013 10:20:44(UTC)
| Reason: Not specified mkraska attached the following image(s): |
Originally Posted by: mkraska Strange bug: If you copy a Hyperlink region with description using Ctrl-Drag, then both original and copy seem to use the same data. If you edit the copy, the original changes as well (also the cursor is shown there).
If you copy using Ctrl-C Ctrl-V everyting is fine. thank you, was my fault. Plugin updated. |
Just found out about this plugin.
Thanks for the work man.
Just a few quick questions,
lets say i wanted to open up a file with a specific program, what would i type into the hyperlink?
for example, lets say i wanted to open up
song.mp3
with the executable
C:\foobar\foobar.exe
song.mp3
with the executable
? You might try the approach shown in post23. Use "'C:\foobar\foobar.exe' song.mp3". It is essential to quote the executable path with ', otherwise windows takes the space as part of the prog name. |
Originally Posted by: mkraska You might try the approach shown in post23. Use "'C:\foobar\foobar.exe' song.mp3". It is essential to quote the executable path with ', otherwise windows takes the space as part of the prog name.
Exactly with foobar, if your song contains some spaces use wildcards (*) instead of spaces (f.e. this doesn't work in vlc; I'll think to another approach or another solution to fix this - maybe a double single quotation to have a double quotation or a context menu dialog...) regards, Davide Davide Carpi attached the following image(s): |
totally missed the apostrophes. Thanks for the update.
Amazing plugin websurfer.
UPDATED- Flags input moved from the placeholder to a dedicated context menu item. This solve double quotes issues involving flags and SMath strings. - PASTE feature works also with the new input way. ( TEMPORARY feature) To update worksheets containing the old syntax ( "'process' flags"): - open the worksheet - save the worksheet - close and open again the worksheet - delete all except the process name from the input placeholder - save the worksheet regards Davide Edited by user 07 October 2013 03:12:50(UTC)
UPDATED
- Fixed critical bug on exceptions' propagation. |
UPDATED
- SMath Studio 0.96.5146 required; - restored red background when the region is disabled; - click on resize markers now doesn't trigger the link.
best regards,
Davide
I am using it with version 0.96.5146 but generation of executable version (viewer) doesn't work for me. Is that known issue ?
Hello, I can't reproduce the issue... could you attach a file that doesn't work for you? Edited by user 04 February 2014 14:36:58(UTC)
The issue is solved. After SMath was restarted it works. Sorry for bothering you.
UPDATED
- Paste as SMath string temporary disabled (this let you paste strings on the canvas freely) |
Joined: 03/06/2014(UTC) Posts: 13 Location: IRVINE, CA Was thanked: 1 time(s) in 1 post(s)
Hi guys,
not sure if it is my issue only, but everything I paste becomes an hyperlink, formulas also. The way I am working now it starting a dummy formula, paste what I need and then delete the rest. Am I missing something? I tried to find a reference to this in the forum but did not succeed. I apologize if the answer is already out there.
thanks
You're right, the cause is a known bug of the clipboard manager (SS-200). I've accidentally re-enabled the feature in some silent update related to API changes.PLUGIN UPDATED- Paste as SMath string temporary disabled. edit not a SMath bug, just a misinterpreted feature. Edited by user 08 August 2014 22:22:28(UTC)
