4 Pages123>»
#1 Posted : 27 July 2013 14:08:26(UTC)
Was thanked: 1402 time(s) in 911 post(s)
Hi all,
Here there is a plugin to add hyperlinks in SMath Studio worksheets and SMath Viewer applications.
Plugin UI languages: English Deutsch Italiano Русский Español
PLEASE REPORT IN THIS TOPIC ANY ISSUE.
  • requirements: SMath Studio 0.96.5146 Nigthly build or later, .Net Framework 2.0;
  • installation: download the plugin from the gallery;
  • documentation: download and unzip the attached archive;
  • sources: if you want to see the plugin sources look in the SVN repository;
  • languages: if you want to have a new UI language look into the documentation's Language folder
Edited by user 14 April 2016 12:59:07(UTC)  | Reason: flags' links
File Attachment(s):
HyperlinkRegion_docs.7z (46kb) downloaded 382 time(s).
thanks 6 users thanked Davide Carpi for this useful post.
on 27/07/2013(UTC),  on 27/07/2013(UTC),  on 30/07/2013(UTC),  on 01/08/2013(UTC),  on 01/08/2013(UTC),  on 01/08/2013(UTC)
Offline mkraska
#2 Posted : 27 July 2013 17:38:45(UTC)
mkraska
That would be highly welcome. In the help system, there is a lot of links which now need to be copied to the adress line in the browser.
Are the links to sm-files supposed to open like the current text regions with href attributes (internal links) or are you going to launch new instances of SMath each time such an internal link is clicked?
Edited by user 27 July 2013 17:41:30(UTC)  | Reason: Not specified
#3 Posted : 27 July 2013 18:43:37(UTC)
Hi Martin Good
Each click open a new istance of the required program.
#4 Posted : 01 August 2013 01:06:14(UTC)
First Beta available through plugin's Gallery.
Documentation and translation sheet in the first post.
Best regards,
Davide
Offline Andrey Ivashov
#5 Posted : 01 August 2013 02:41:32(UTC)
Was thanked: 2012 time(s) in 680 post(s)
Absolutely great! Thank you for such a wonderful plug-in!
P.S.: I love these icons and common approach you use.
P.P.S.: If you found any limitations in SS interfaces, just let me know.
on 01/08/2013(UTC)
#6 Posted : 01 August 2013 13:20:12(UTC)
Thank you for your program Andrey Good
Don't worry, I'll do it Biggrin
Offline mkraska
#7 Posted : 01 August 2013 14:52:20(UTC)
mkraska
SMath crashes if a hyperlink region is copied by Ctrl-drag.
#8 Posted : 01 August 2013 16:33:13(UTC)
Fixed, test the update...
Best regards,
Davide
on 02/08/2013(UTC)
Offline mkraska
#9 Posted : 02 August 2013 08:24:24(UTC)
mkraska
Works fine, thanks a lot.
Offline mkraska
#10 Posted : 02 August 2013 09:34:35(UTC)
mkraska
I am trying to build links to the plugin installation directories in the documentation.
Under windows, the %APPDATA% and the SettingsDirectory() approach work, but how is that under linux? Could the linuxers in the community please test the attached sheet? It contains links to the install directory of the 3D Plot plugin by uni.
@Andrey: The nice feature of being able to paste target strings to the hyperlink placeholder prevents me from pasting the target expression involving SettingsDirectory() directly to the placeholder in the link region. This rises the question, why there is special treatment for string constants in math expressions at all.
File Attachment(s):
Hyperlink.sm (4kb) downloaded 111 time(s).
#11 Posted : 02 August 2013 14:05:07(UTC)
I've not yet tested the plugin under linux, I don't know...
I suppose that's possible for texts that contains characters not available for the variable names (such spaces or slashes and backslashes), when you paste something in a placeholder; for the canvas someone may would paste text as text, so a "paste as" would be needed (or a "post-paste context menu item" like in MS word)
Edited by user 02 August 2013 14:10:28(UTC)  | Reason: Not specified
#12 Posted : 03 August 2013 00:51:25(UTC)
UPDATED
- Support for SMath Viewer
best regards,
Davide
Offline mkraska
#13 Posted : 04 August 2013 00:34:13(UTC)
mkraska
The hyperlink region does not respond immediately to font size changes. You need to close and re-open the file in order to get the desired effect.
Normally, I try to avoid any font changes. In the given case, I tried to build a table containing links which were supposed to fit in a single grid spacing.
File Attachment(s):
Plugin index.sm (24kb) downloaded 83 time(s).
#14 Posted : 04 August 2013 01:00:43(UTC)
I know, is an issue of CustomRegions (2D plot, XY Region, etc...)
I've not opened a specific topic, but is already mentioned here (1st image, "original" -> appearance font-size different from real font-size)
best regards,
Davide
Edited by user 04 August 2013 01:03:07(UTC)  | Reason: Not specified
Offline mkraska
#15 Posted : 10 August 2013 01:35:53(UTC)
mkraska
SMath crashes when I try to edit the input expression of a hyperlink.
I write concat with three arguments, fill in the first and the last. As soon as I want to type to the second placeholder, the crash occures.
#16 Posted : 10 August 2013 02:07:15(UTC)
Fixed, please test the update Good
best regards,
Davide
on 10/08/2013(UTC)
Offline mkraska
#17 Posted : 10 August 2013 02:35:26(UTC)
mkraska
That was fast... Thanks a lot.
#18 Posted : 10 August 2013 03:02:03(UTC)
You're welcome; I've already noticed the bug working to another plugin Wink
Offline mkraska
#19 Posted : 10 August 2013 12:56:30(UTC)
mkraska
When multiple hyperlinks are selected, the custom context menu action "Show link target" is applied only to one region. The other (system) actions can be applied to all selected regions at once.
#20 Posted : 10 August 2013 13:11:22(UTC)
It is a CustomRegion bug, I've reported this behavior to Andrey some day ago Wink
Edited by user 10 August 2013 13:13:03(UTC)  | Reason: Not specified
4 Pages123>»
