Some issues when copying CustomRegions (like built-in 2D plots) with CTRL+drag: - when the description is enabled cause an oversized selection of the output; if the base region have a description and is disabled, some glitches appears - if you select the original region and you change the font size, the clone have the same font-size of the original (CTRL+V display the output with the correct font-size) best regards, Davide MOVED IN THE BUG TRACKEREdited by user 22 March 2014 21:55:24(UTC)
| Reason: Not specified Davide Carpi attached the following image(s): |
Thank you! I'll check it.
