  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,329   Location: Italy Was thanked: 1173 time(s) in 772 post(s)
Some issues when copying CustomRegions (like built-in 2D plots) with CTRL+drag: - when the description is enabled cause an oversized selection of the output; if the base region have a description and is disabled, some glitches appears - if you select the original region and you change the font size, the clone have the same font-size of the original (CTRL+V display the output with the correct font-size) best regards, Davide MOVED IN THE BUG TRACKEREdited by user 22 March 2014 21:55:24(UTC)
| Reason: Not specified Davide Carpi attached the following image(s): |
  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,478   Was thanked: 1746 time(s) in 592 post(s)
Thank you! I'll check it.
