It could be possible to decompile those dlls to make the source code compatible with 64-bit systems
This is not a good idea. It is much easier to use a virtual machine and run SMath Studio there. Fortunately, EFI is almost no one used. On the Internet it is difficult to find a library for Mathcad created by users. As for mathlib.dll, I have the source code. So I can rewrite the code in C# or C++/CLI. |
ugh..you'd be scrubbing your hands like the famous surgeon trying to revive a monster I think you mean to prepare some package to load within virtualbox or alike ?
Yes , but there is another solution: CorFlags Conversion Tool. Andrey advised me. You can use this utility to change SMathStudio_Desktop.exe (set the 32BIT flag). Maybe this will help. The new program will run as a 32-bit program. Edited by user 19 June 2013 23:27:48(UTC)
EFI plugins can't be made with .net. This interface is designed to work only in unmanaged code (C, C++, Delphi, Fortran, assembler). For the 15 years of its existence nobody (almost) used it. |
Originally Posted by: uni uni, could you explain please in few words, what does this actually mean? What is the connection between, say, Fortran 2003 (IVFC XE 12) and EFI plugin? Cheers, Radovan |
This means that you can write a function in any of these languages. You can use the compilers of these languages to create extensions for SMath Studio. Unmanaged code runs much faster. You can use the EFI interface as a wrapper for the old code. You can write an extension for SMath Studio directly on Fortran. |
Originally Posted by: uni This means that you can write a function in any of these languages. You can use the compilers of these languages to create extensions for SMath Studio. Unmanaged code runs much faster. You can use the EFI interface as a wrapper for the old code. You can write an extension for SMath Studio directly on Fortran. We mentioned such a possibility here and there on the Forum. I also nagged about this few times. If there could be a way to make some SMath packages using any of older Fortran/C/C++ libraries, and use them within SMath...to be honest, it seems to me like a science fiction I remember there was such a possibility in Mathcad long time ago. As I remember, the EFI thing was in case (USEREFI mechanism). As I remember, there were some preferred compilers at that time (Fortran/C/C++, than Fortran was abandoned). From my point of view (as an average user) it was a bit complicated. Therefore, I've never tried myself to make a user defined DLL in Mathcad. I just know that some Mathcad Handbook writers used this and expanded Mathcad with their own functions packaged into DLLs. I actually am not aware that anyone made any DLLs from some old and well established Fortran or C/C++ libraries (I might be wrong regarding this). Regards, Radovan Edited by user 21 June 2013 13:38:33(UTC)
Joined: 26/05/2013(UTC) Posts: 1 Location: Schleswig Holstein Was thanked: 1 time(s) in 1 post(s)
Hello uni! Thank for all of your nice plugins. I like to give a hint for using the mcadefi plugin with windows 64. I found an article about the dll issue: http://blogs.technet.com...amework-not-working.aspxI followed the instructions and now the efiplugin works fine with windows 7 ultimate 64 best regards matthias
1 user thanked matthias for this useful post.
I did it for myself. Such libraries are much faster than SMath Studio plugins. You can use the Fortran code, just rewriting it under the Fortran 2003 standard. Fortran is still used. I wrote a simple fortran library in Visual Studio 2010 (with IVFC XE 12). This dll works in Mathcad too.
In the Developer's Guide (in the Mathcad Help) is used a workaround to use Fortran libraries. They use a wrapper in C to call functions from Fortran library. I do this directly. |
Originally Posted by: matthias This one does not work for me. Still in the efi.txt 6/21/2013 2:51:32 PM [Error] is not a valid Win32 application. (Exception from HRESULT: 0x800700C1) Regards, Radovan |
Originally Posted by: uni I did it for myself. Such libraries are much faster than SMath Studio plugins. You can use the Fortran code, just rewriting it under the Fortran 2003 standard. Fortran is still used. I wrote a simple fortran library in Visual Studio 2010 (with IVFC XE 12). This dll works in Mathcad too.
In the Developer's Guide (in the Mathcad Help) is used a workaround to use Fortran libraries. They use a wrapper in C to call functions from Fortran library. I do this directly. You said that you wrote a simple fortran library which works both in SMath and Mathcad. That is very interesting. It seems very easy to accomplish this, when you explained this , but I think there is no chance to do that by myself. Do you plan, by any chance, to make a plugin by using some existing, free available, Fortran numerical library? Regards, Radovan |
There are well-known IMSL® Numerical Libraries. Many people use this library, but it is commercial. This library exists in different versions (c# one of them). It can be used to extend SMath Studio. Edited by user 21 June 2013 16:33:16(UTC)
| Reason: Not specified uni attached the following image(s): |
I used it long time ago. I remember IMSL FORTAN routines on some VAX machine, more than 20 years ago. Than on some Fortran, MS Power Station 4.0 and Digital,Compaq Visual Fortran, some 10 years ago (sometiimes used NAG as well). I have'nt been using it for a while (10 years or so). Some of them are free. Many years ago I poked into Netlib free library ( Fortran company). I switched to some more "light weight" software . When you said that it can be inside SMath, I believe you - but it seems to me like a "science fiction" . Regards, Radovan Edited by user 21 June 2013 16:56:40(UTC)
It's not so hard to use IMSL library now. Simple example (c#) - calculating special function (Imsl.Math.Sfun) Gamma(x):
using System; using System.Reflection;
using Imsl.Math;
public class Sample { public static void Main(String[] args) { try { Console.WriteLine("Sample IMSL C# Numerical Library application." ); double result = Imsl.Math.Sfun.Gamma(5.0); Console.WriteLine("The Gamma function at 5.0 is " + result); } catch {} } }
The program requires some additional files: ImslCS.dll, LicenseFlexLM.dll and license.dat |
Originally Posted by: omorr Originally Posted by: matthias This one does not work for me. Still in the efi.txt 6/21/2013 2:51:32 PM [Error] is not a valid Win32 application. (Exception from HRESULT: 0x800700C1) Regards, Radovan Try this assembly with the 32BIT flag. |
on 22/06/2013(UTC), on 26/06/2013(UTC)
Ha...it worked now . efi.txt is full of text now explaining what functions have been loaded Thank you uni, Regards, Radovan P.S. As I unpacked the entire archive OKAWSP6.dll error appeared. Explained here |
